Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
REBAR 3D DRAW ORDER
REBAR 3D DRAW ORDER
mgilliver
REBAR 3D DRAW ORDER
mgilliver
Hi All
I've been creating some rebar cages in beams etc, and colour coding bars etc. However, when I try to create a good 3d view of it, the draw order of the rebar is very random and I can't find a way to change it.
Example attached. The links should be around the main bars and therefore obscure them, but they don't show that way. Is this a setting I've missed?
ovidiu_paunescu
Hi @mgilliver
Try turning off unobscured in that view for all the bars (select bars > properties > view visibility states > uncheck unobscured).
Make the host transparent so that you see the bars.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
mgilliver
Hi - I've found a couple of workarounds, but nothing perfect.
Option 1 - show unobscured and solid - but model as hiddenline (no transparency) - if I use any transparency, the rebar is also going transparent and so you start to see bars through bars.
Option 2 - show as wireframe, but without unobscured.
The problem there is that it looks wrong.
Option 1 is good, but I have other cast in items in the concrete that I want to be visible, and they aren't.
ovidiu_paunescu
You can override the transparency just for the elements you want transparent.
Sometimes I use a filter with multiple categories that makes all the elements with the comment "transparent" transparent, or I right click the concrete element > override by element > Transparency
