QA with Revit
QA with Revit
nuwan.senanayake
QA with Revit
nuwan.senanayake
Can someone advise if there is a way to do on-site QA with the Revit model?I am trying to check installed steel members against the model and mark them with a deference colour or something
jay_colcombe
Really you would need Autodesk Construction Cloud (ACC) as it is made for this type of application but unfortunately it does come at a cost!!!
This would allow you to upload your models to the cloud, open the model and sheets on a tablet for instance and then you could assign Issues and Markups onto the plans and models in the views where possible anomalies arise.  You can add text and photos to the issue and it even noted the location/coordinates and these can are directly linked to the Revit Issues Addins to be addressed later.  You can even create reports and copy other member in the Project in so they are aware and receive email confirmation.
I have seen where a PDF was used on a tablet and they just put highlights of Red and Green and circled number to note information and related notes but this is a little basic and additional notes are still required to log differences.
if you wanted to use Revit you could add a Parameter to the elements for checking with a Yes/No function and set up a View with a Filter for Yes = Green, No = Red and select the element and tick/untick the box but obviously this would be quite long winded and still an amount of user input is required.
In an ideal world it would be great to walk around the structure where each element has a barcode/QR scan and this gives the information of the member and if the coordinates are correct it correlates with the Model on the tablet and marks as Green!
Jay Colcombe
Autodesk Certified Instructor
nuwan.senanayake
Thanks Jay . Answer is very helpful
Could you please give me link/Video with directions to use Revit in this process as you describe below
jay_colcombe
Markups using Autodesk Design Review (Free)
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-CE67846D-C533-46DF-A702-7ECF2BB67DC8
https://youtu.be/s7jJx2kfDVQ?si=nPjz8oksaKxfdkMW
Autodesk Construction Cloud (Paid)
https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-CF6A4654-FA7A-4EEC-AEE1-9DEC78865DC5
https://youtu.be/KeLdvIAEw3Q?si=xbfbMicJx8E7Uf71
There is a lot more out there so hopefully these will get you moving forward!!!
Jay Colcombe
