Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Project Units
6 REPLIES 6
765 Views, 6 Replies
Project Units
I have a problem with the Project Units: when I try to find an area of the room, the sign of square meters changes and becomes "I" instead "2".
6 REPLIES 6
Hello @Anonymous
What did you change in the project units? Length or Area? please confirm.
I suspected that you changed the length not the area.
Thanks.
Viveka_CD
Hi @Anonymous
Can you send us a file to troubleshoot? I can share a private folder to upload.
Information on working with Revit Project Units and Annotation Units HERE
Looking forward to your reply update.
Tags (1)
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
D.Arch
This is a Revit bug.
You need hotfix 2018.0.2 http://up.autodesk.com/2018/RVT/Autodesk_Revit_2018_0_2.exe
2017-09-04_0645
in reply to: D.Arch
D.Arch написано:
2017-09-04_0645
Установила Hot fix. Помогло - верхние индексы наконец-то появились. Большое спасибо Дмитрий!
Viveka_CD
Hi @Anonymous
Glad to hear that you got this issue resolved!Smiley Happy
You wrote:
________________________________________________________________________________________
Installed Hot fix. It helped - the upper indexes finally appeared. Many thanks to Dmitry! Smiley Happy
