Project Base Point Angle rotation
RameshBedadala
RameshBedadala
Hello
I am trying to match my structural co-ordinates with the arch model. I have acquired co-ordinates and linked in the structural model into Arch and moved the structural model and saved back the co-ordinates. As you can see everything matches except for the angle. I have tried rotating the north, but unfortunately the whole model rotates and lands in the wrong location when I link in. How do I match the angle?
Thanks in advance
@RameshBedadala wrote:
Hello
Thanks in advance
Your workflow is conflicting.  Either acquiring coordinates or publishing coordinates, not both.  Do it again using these steps:
- Unlink structural model
- Manage > Coordinates > Reset Shared Coordinates
- Link Structural model in center to center > Move + Rotate it to align with your model
- Acquire Coordinates
RameshBedadala
Thank you for your reply. I am trying to link in Arch model (which has correct coordinates) into structural model.
RameshBedadala
I rotated the true north and everything is fine now
Thank you
lim.wendy
Hi @RameshBedadala,
Thanks for reaching out to the forum and for confirming that Toan's suggestions work.
I will go ahead and mark this thread as "Solved." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Remember, if the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
