Problems with wall foundation dimentions
I tried to place a wall foundation in my design. I selected Edit Type, Duplicate and then changed the depth to 250mm. However, when I placed the foundation it's depth changed to something like 308mm and I don't know how to adjust it because now it doesn't fit my dimensions. Is there anyone who can help me with this?
could you add more images (select wall, select foundation, show foundation type) so i can see properties.
Do these help?
twebb4CYQY
All your clipped properties look as they should.  Is this happening with just the one footing type?  What happens when you use the same footing type with 300 depth?  And have you tried deleting the type from the project and created a new one?
