Problem with the function copy/controle
hmunsell
can you translate that message :-).
Howard Munsell
vick1z
which language is this, pls explain issue in English :
seems you had copy monitor error, pls check the link below
http://help.autodesk.com/view/RVT/2018/ENU/?caas=caas/screencast/Main/Details/4a6b59c7-775a-49af-835...
PavelAnd
Hi. Look this link and your journal.
Best regards, Pavel Plotitsyn.
" a serious error has occurred. the current action has been canceled. you are strongly advised to save your work in a new file before continuing " that's the message
