Problem with split using Precast.
edgarsceplis09
edgarsceplis09
Hi, when i try to split my Generic 300mm thick floor i got a error: Hollow core slab with invalid thickness. Change the selected template family in Config or adjust the thickness of the slab to match. I tried to use different types of floor, different thickness (300,500,1000mm) and use different slab families, so if you have any ideas to solve it, please report.
jay_colcombe
As previously suggested
"Hollow core slab with invalid thickness." when using the Precast Split tool to create a Hollow Core...
Jay Colcombe
Autodesk Certified Instructor
