Problem with Dimension after changing Family type
YairaGabay
Message 1 of 9
YairaGabay
I’ve download or create a Casework family type object and decided to change the family type to Furniture type.
By default, in a Furniture type family, when giving dimensions to the object I don’t get the object's height and in Casework type I do get the Hight of the object.
 In this case, after changing family’s type I continue to get the object's height as in a Casework.
 Is it possible to change this behavior so that I will not get the Object’s height?
Replies (8)
Message 2 of 9
L.Maas
No I believe this is not possible. When changing to casework this parameter seems to be added/integrated and not be able to be removed when changing to a different type.
Solution might be to:
-Copy your elements to a new family template.
-Use the parameter
-Set the formula in the family editor to a fixed value (e.g. 0 or 9999), then it can not be easily (mis)used
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 9
shuaib009
Better you post this in Revit Architecture Forum
Message 4 of 9
YairaGabay
Every one say to post to another forum , I just want to post it to the correct forum
So if I have questions about Revit application which one is the best?
Message 5 of 9
shuaib009
hope @ennujozlagam  will resolve your problem.
Yaira, since you had architectural elements in your question, that's why I suggest you to post in Architectural forum.
To resolve the issue Quickly you better attach the file in which you problem.
Message 6 of 9
YairaGabay
Thanks a lot
I've tried it, not so Smoothly...
anyway thanks a lot for your help
Message 7 of 9
YairaGabay
Thanks a lot
Message 8 of 9
YairaGabay
You mean that this kind of question to post in Structure Forum?
Message 9 of 9
shuaib009
I mean to post in Revit Architecture Forum, (Since the furniture belongs to arch.), that is here 👉  https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
