Problem Mirroring Structural Connections
I am trying to mirror a custom connection to another joint. However, when I mirror the custom connection, the connections seems to be floating in the air. Does anyone know a solution to this problem. Please see attached image.
Thank You,
Chris
MostafaElashmawy
I would recommend rotating by 180 degrees instead of mirroring.
Mostafa Elashmawy
Thank You for your reply, but it doesn't seem to working.
Best Wishes,
Ahmed_Muharram
if you are using revit 2020 i will recommend using copy propagate connection
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Thank You for all your support. However, I went pre-existing connection in the end and it worked.
Best Wishes,
Chris
