Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Problem in Revit 2020 & 2019
7 REPLIES 7
Message 1 of 8
1337 Views, 7 Replies
I downloaded version 2020 and found this problem (Not showing up Any list containing a drop list)
It does not exist in any other program (AutoCAD / Photoshop / CorelDraw / Microsoft Office)
I have reviewed all the steps of computer repair but I Can't not been successful to solving it
I replaced it with version 2019 and found the same problem
I do not know What is the problem and what is the solution that affects the work on the program
7 REPLIES 7
Message 2 of 8
What do you see under hardware?
Message 3 of 8
in reply to: ToanDN
HP Omen 15-BTO Gaming Laptop
Processor Speed (GHz) : 2.8GHz
Processor Type : Core i7-7700HQ (7th Generation)
Number of Processor Core : Quad Core
Display Size (Inch) : 15.6 Inch
RAM Size : 16 GB
Video Controller Manufacturer : NVIDIA
Graphics Card Capacity : 4 GB
Memory Technology : DDR4
Operating System Type : Windows 10
RAM Size : 16 GB
Message 4 of 8
Is it a 4K screen? Change the Windows Display Scaling to 150% or less. 100% is ideal but it can make everything tiny on a very hi-res screen.
Message 5 of 8
in reply to: ToanDN
Is it a 4K screen?  I'm not sure but the Max resolution Are available is 3840 X 2160
When Windows Display Scaling changed to 125% Nothing happened
But when it was changed to 100% the problem was fixed and I can not read any word in any list becous it is very small
Both images have the same length (screen length)
Message 6 of 8
Change it to 150% and if the text are still too small then reduce the resolution to something less than 3840 x 2160.
Message 7 of 8
in reply to: ToanDN
I don't know what should to do
Message 8 of 8
You will need to at least restart Revit after changing the screen resolution. I think you may even need to restart your computer.
