Problem export Revit to NWC ( maybe structural framing issues)
Tengbimkub
Tengbimkub
I am unable to export to an NWC file. I found that the problem is caused by the "Structural Framing" category, which uses commands in the "Steel" tab, such as the "Cope" or "Steel Connection" commands. I have exported in Detail Level = Medium, and I have tried to turn off the display of Structural Connection, but it still does not work.
hmunsell
what version of Navisworks are you using?
  • the screen capture you sent looks like your using 2019.
what version of Revit are you working in?
have you tried Appending the RVT file into Navisworks?
  • when you append a RVT file into Navisworks it makes an NWC. not ideal, but it would narrow down where the issue is.
Howard Munsell
