Hi everyone,
I’ve been experiencing issues with printing to PDF using Revit, from versions 2019 to 2024. Despite having installed all available updates, I’m encountering a couple of problems.
When printing to PDF, certain elements on my plans, such as colors on the deck and filled regions, seem to shift or distort. I tried exporting to PDF instead of printing, which resolves the issue with shifting elements but introduces a new problem: the text in the PDF sometimes has inconsistent spacing, with random large gaps between letters or words.
I’m running out of ideas on how to produce a clean PDF. Does anyone have any suggestions or solutions?
Thank you!
Hi everyone,
Thank you!
Solved by ennujozlagam. Go to Solution.
try to install another pdf driver and see if helps like CUTEPDF
Use Revit native Export to PDF, or DiRoots Prosheet Export to PDF.
