Precast Shop drawing face issue
I need to show my inside wall near face on my shop drawing on our precast panels.
All i see is detailView: Elavation front but i want (detailView: Elavation Back)
teodorb
Hi @Anonymous,
Go to the your titleblock (it should be located here C:\ProgramData\Autodesk\Structural Precast for Revit 2018\Families\en\Title Blocks). Open the title-block you will be using in the configuration menu, select the sideview and copy it where you need it. Select the copy and in the properties palette, under viewing direction, type '-X'.
Let me know if you need additional information.
Kind regards,
Bogdan Teodorescu
Product Owner
davePFZQS
When I go to the structural Precast folder in the libraries, All the folders are empty, Mo mounting parts no title blocks "nothing" where can I get all the elements that should be in this folder, OR does it come empty ands we have to build or create the families
teodorb
Can you show a snapshot of the Configuration window. Just press Configuration and have a snapshot with the dialog to see the location for your families.
Thank you,
Bogdan Teodorescu
Product Owner
