Hello @aleksei.tkachenko
Two things to ask then comes the clarification
- From your screencast, it shows that the dwg has already been linked once before into the project. The question is, when u linked it the first time did you position it properly in revit (to where it should be) then published the coordinates to the CAD? (Or viseversa did you acquire the coordinates from the degree?)
.... If you neither published or acquired coordinates before then the two files do not share the same coordinate system and you can't use Auto-By Shared Coordinates option
- second question, if the dwg has been previously linked and you already have an instance of it in the Revit host model, what is the purpose of linking a second instance? Why not reload the already existing one?
.... The reason I ask is that there might be a chance that the CS in the dwg might have been modified by someone other than u who has access to it (mistakes happen and in such case the coordinates need to be republished to the CAD to fix it or better say realign them) or the surveyor revised his survey and in such case the CS need to be reset either from the revit published to the dwg or acquired from the dwg (the latter happens when the surveyor revises something or when the location of the site has been changed)
- third question, while you were in the process of setting out your project in revit (I can see the project base point and the survey point are not in their original location) you DID NOT move/tamper with the Start UP origin???? Or did you?
.... Asking because one needs to consider the fact that the project base point may not be un-clipped and relocated further than 10 miles (best <8 miles) away from the Start UP origin. (The start up origin is invisible and it is not the survey point) if this happened you would continue to receive that error (too far from project origin) even if coordinates are shared
PS: best practice is to have the site on a separate revit model and the u link ur revit building model into the revit site model (but first we try solve ur issue before getting into this)
Sorry for any typos; I am using my mobile
