Plate Type Parameters
yaser.alipoor
yaser.alipoor
Hi everyone
I have a problem with the plate type that Revit defines automatically.
The format of the plate type in Revit is "PL Thickness(mm)xWidth(inch)xLength(mm)"  [for example PL 8x5 1/8"x200]
but I want all the parameters to be in (mm) [for example PL 8x130x200]
 I would be grateful if anyone could help me to solve this issue.
Ahmed_Muharram
you should start with a metric template and use metric families
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
yaser.alipoor
I always use a metric template for my projects.
FYI, I have used plate command in the steel tab and it has been defined by Revit in the first place and we don't have permission to change it. ( When you select a plate, "Edit Type" is disabled)
Even if I use an imperial family and upload it to my metric project, Revit automatically changes its parameters into the metric.
spahlevan
Hi there!
Did you find the solution? I am using metric template and having the same issue!!
#Revit 2021
yaser.alipoor
Linkedin Go to the edit family of the plate tag and use these labels.Go to the edit family of the plate tag and use these labels.
RDAOU
@spahlevan
See GIF below
In the Schedules
  • Use Combine Fields and Combine Thickness x Length x Width
  • Add a Prefix PL
  • Add separators x
In Tags: Simply create a Label which Combines the parameters Thickness x Length x Width
serhangencSPM
Community Visitor
Community Visitor
It's the year 2026 and this problem still persists. Very interesting.
