Plan Region and UP View Direction Structural Plan View
Moshe-A
Mentor Mentor
Moshe-A
Hi Guys,
i have search the forum and could not find any thread on this:
it seems Revit is stuck in view range dialog box when trying to set  Bottom + Cut Plane + Top + View Depth Level
when in structural Plan View + UP View Direction
any one seen this and have solution?
thanks in advance
Moshe
Hi Moshe-A,
Can You show me your problem?
When in structural plan + Up view , you can set Cut Plane + Top + View Depth Level.
"Bottom" is not meant in here
BR,
Nghia
Moshe-A
the attached picture shows a structural plan (view direction up) and a plan region inside room
the view range (for the plan region) on the left  shows the planes levels:
top  plane = 6' 0"
cut plane  = 3' 0"
Bottom     = 0' 0"
(level 2 is at 10')
the view depth level only excepts a value from 6' an up
this puts 'Bottom' as the lower level and view depth can only be above the top level
does this reasonable?
and look at the room... the Ceiling is seen and not bound to the view region
Moshe
So it is a Reflected Ceiling Plan?
Hi Moshe-A,
I not look at a picture in here.
But you can use "Reflected Ceiling Plan" to replace "Plan Region", it's advised by @ToanDN
Thks for your support, @ToanDN
Not seeing any picture here either so I just wanted to confirm.
Moshe-A
how about this one?
