Place rebar in structure foundation
qchenTPPXV
Message 1 of 11
qchenTPPXV
Greeting,
I use the default Revit family pile. It is structure foundation type but it doesn't have the option to place the rebar. The family is attached. Any help would be appreciated.
Replies (10)
Message 2 of 11
apjones
As far as I know, you cannot place rebar in the family editor environment, only in the active model.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 11
qchenTPPXV
Agree. I tried to place it in the project but it doesn't allow me to.
Message 4 of 11
M_Meshal
You cannot place the rebar because the pile defined as steel pile, to change it do the following steps:
Open it in family editor > go to family category and parameter M_Meshal_0-1713608554717.png  > change model behavior from steel to concrete
Save the family and reload it to the project.
Message 5 of 11
qchenTPPXV
Thank you so much. it works perfectly.
Message 6 of 11
qchenTPPXV
I have a follow up question. I created a revit family and set model behavior to concrete. However, it doesn't work as expected in project. The file is attached. Do you mind help me take a look?
Thank you very much for your help!
Message 7 of 11
M_Meshal
Yes Sure!
Could you please explain what is the issue exactly?
Message 8 of 11
qchenTPPXV
Thank you for getting back to me. The pile family I created on the top left doesn't allow rebar to go through. The material behavior is set to concrete. Do you know the solution?
Message 9 of 11
M_Meshal
I believe that you want to extend the steel pile inside the concrete one.
If so, you can't do it in the current status, because by default Revit will not allow you to extend the steel pile (which has structural column category) inside the concrete pile (which has structural foundation category).
To solve this issue you have many solutions:
1- Use the steel pile family (structural foundation category) as per the following photo:
you can extend this one inside the concrete pile
2-Insert steel column family (which you are using in your photo), inside the family of concrete pile, extend the steel pile and modify the family accordingly, then reload the family into the project.
3-Use structural column category to create the concrete pile, then insert the steel column inside the concrete one.
Message 10 of 11
rafaelPD66Z
if you don't mind not having 3D reinforcement but 2D automatic reinforcement included in the family, you can check this video. I think is easier when you don't need to quantify steel rebar.
https://youtu.be/R-MpEMFS9YI
Message 11 of 11
Raishacana
Observer
Observer
THANKKKSS FOR THE HELP!!!!!
