Phase filters not working on structural framing elements
I am working in a model with multiple phases. Certain elements such as walls, structural columns, etc are properly overridden when viewed as previous phases. Other elements such as structural framing elements are not effected by the phases/ phase filters. Does anyone know how to fix this?
MostafaElashmawy
Are you assigning these elements to the correct phase?
Mostafa Elashmawy
hmunsell
What is the full name of the Phase filter your using, the screen capture only shoes "Show Previous..."
If I am reading it correct… Rim Framing is Prior to Joist Framing in the phase list, so if you want to see the “joists” in the “rim” phase I don't think you will be able to. Rim is prior to Joist and Revit can’t show the Future.
Howard Munsell
