Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Parametric Column - Blend
3 REPLIES 3
Muhammad_Tahir
785 Views, 3 Replies
Trying to create a parametric column - Facing some issues - I need blend on curve path and both faces have different radios - need some architectural work on it as well...
3 REPLIES 3
Luiscko
in reply to: Muhammad_Tahir
You can try to create diferent families for your complex colum with this parameter and then you join in family new usign your diferent families inside this one like nasted families.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
You need two swept blends and join them.
Muhammad_Tahir
in reply to: Luiscko
Yes is done. Thanks..
