Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
og1100asu.dll is not for this windows version
1 REPLY 1
2288 Views, 1 Reply
Hello autodesk people,
I am installing Revit 2016 and Revit Structure 2016 on a box and when both are done in the revit folders is the dll
og1100asu.dll.
This dll should have a timestamp off 1-12-2014
and on some machines is have this but sometimes with de Revit structure installation the dll has a new timestamp 25-6-2016 or something.
I can not find where this timestamp comes from.
i use a deployment source with the sccm batch scripts.
if i copy the right dll from de revit installation to de structure installation everything works again, but i want a good install sequence.
any idea?
regards
Roger
1 REPLY 1
solved it, it was a file copy probleem with adjusted the tiimestamp.
