not possible to change rebar constraint
JPNR87
JPNR87
I dont manage to change shape 21 rebar constraint
cant move to sidescant move to sides
how to solve it? movin rebar doesn't help ( overlaping)
ovidiu_paunescu
Hello @JPNR87
Could you add a sample model?
It looks like the vertical bars have the style set to stirrup/tie, since the U shaped bar can constrain to them.
If you need the U-bar segments to move independently, you can set the segment constraints to the host faces.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
