Assigning and Designing Connections in Revit Structures
Hello, I am using Revit Structures and Robot Structural Analysis for seismic simulation of a high rise.
I am in modelling part of Revit, and I want to assign the right connection types to the plates/planks to column, and structural wall to floor slab etc... (such as moment connection between the plank and the column). These involve different materials as well. *Mass timber to concrete
Can you help me on this? Thank you very, very much
Luiscko
For this thing you need to select your analytical model and chose the particular function that you want to use before send to Robot to do it well.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
