Need help with linked files showing hidden lines
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I work for a Structural Engineering company and still relatively new to Revit.
We have an Arch'l model that we link into our Structural Model. We had made backgrounds in the Arch'l model with how we want the model to appear, information we want shown from the architect and so forth. We then proceed to insert the structure on our model. The problem I'm coming across is this. We do not redraw walls nor do we use the copy/monitor.
We want walls shown below a plane to show up as hidden based on how its being cut. So if you have a building thats rectangular and only show a square section of it being a sloped roof with overhangs and the ends are shown as parapets. The bearing wall should show up as solid where the parapet is, and transition to hidden at the sloped.
Currently when I set up the backgrounds on the arch'l model. But when I link it into mine, the visibility doesnt transfer. Even if I set it to linked model and to the background view thats created for that purpose.
anyway this can be fixed so that what I see in the linked model can be transfered to the new model.
