naming the headers of the sections
不适用
17,082 次查看
3 条回复
1 条消息(共 4 条)
不适用
hello everyone,
I would like to know how can i add a name into the section header, does anybody knows a good tutorial in which i can see how is this made?
0 个赞
已接受的解答 (2)
17,083 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
L.Maas
已接受的解答
When you place a section and look at the type parameters you will see that the section head is another family
When you edit that section head family you will notice it uses several labels. You can add additional labels. However in this case it is limited to the parameters given. As you can see it is not possible to add your own (shared) parameters.
So you are limited to the parameters given
Louis
Please mention Revit version, especially when uploading Revit files.
0 个赞
3 条消息(共 4 条)
不适用
But can I give a specific name to the header? And in case that I can, how can I do it?
0 个赞
4 条消息(共 4 条)
EdwinG
已接受的解答
As Louis said open the section head family then you have to make a new or copy an existing label edit this label see pics below
You can create completely your company standard section head with the labels you like.
save as your section head family and load it into your project.
Parameter "View Name" is editable as you wish.
0 个赞
