Mover Rebar in a Set - Enhancement
MichaelWSullivan
MichaelWSullivan
Love this new feature, however could this feature be enhanced such that individual bars in set could be moved vertically in a similar manner as current feature? i.e. move bars up or down at select locations where there may be a depression or embedded components within the concrete host. See attached
ovidiu_paunescu
Hi @MichaelWSullivan
You can move those like you are showing.
For easy selection, you can click Edit Bars and the bars from the selected sets are isolated. You can then select the individual bars (by clicking or window selection) and move them in any view and any direction. You can also rotate the bars.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
MichaelWSullivan
Thanks Ovidiu, should have tried prior to posting message. Hope you and the rest of the Bucharest team are doing okay considering the major crisis next door. Will try feature as suggested, I'm assuming that this works with Path and Area reinforcement as well as hosted rebar?
ovidiu_paunescu
Thank you Michael, we are fine!
This works for path reinforcement, but not for Area reinforcement. The latter is special, and when you select the system and click edit bars, what you are selecting and moving are the "uncut" bars. You will notice this when bars are cut by an opening. Those uncut bars only move inside their plane and can't be taken outside the area boundary.
