miter command
miter command
RJK42
miter command
RJK42
I need to miter the bottom tube to meet flush with the vertical and horizontal tube.  I'm not having any success with it
Any help will be awesome!
Cut the angled tube by two ref planes.
hmunsell
what version of Revit are you using?
could you use the Steel Modifiers tools?
Howard Munsell
RJK42
I am using 2020 and when I do use that nothing happens
RJK42
I selected "saw cut" under miter and the 3D looks correct but the section still shows the hidden lines
Also I'm having issues with my welds
See attached image
I cannot select the plate and angle iron
