Missings in revit library folders.
Hi all.
I had already installed the libraries of Norway, Sweden, Romania, Finland...
In fact i couldn't find Europe specific in any of these Euro code English version country libraries..a snap shot is given below for reference(in Belgium)
where do I get these.
this is of great importance kindly reply...
Regards..
NQ_GCE
Hi Arunpillai,
Attached you will see an image from Autodesk of where to find all eurocodes for steelwork, if not I would suggest re-installing.
I hope this helps.
Hi Nathan..
thanks for your reply
I checked all folders as specified in the attachment of certified families.....
but couldn't find Europe specific folders....thinking to re-instal
Regards
NQ_GCE
Hi Arunpillai,
If you click uninstall, you should have an option to repair/reinstall? this will allow you to add what you need rather than totally uninstall.
Nathan
Taweepong.S
Hi ,
Please check solution in this link below ,
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Hope it can be work for you ,
Regard ,
Taweepong S.
I already tried this way....i have those country folders.. but the europe specific folder is missing both in 'structural framing' and 'structural column' folders of euro code english version countries.....
i reinstalled ...still the problem is there....
regards
