missing third party updater
BJX916_XUANWU115
Message 1 of 10
BJX916_XUANWU115
Hi everyone.
I am using Revit 2025, I closed the model yesterday and uploaded the model to Autodesk viewer.  When I reopened the model, a warning popped up:
I did some research and found this from Autodesk:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-Missing-Thir...
But the problem is I didn't use any plug-in when I created this model, and this is not a central model, all I did just uploaded it to Autodesk viewer, then why did I get this problem? And which solution should I take that won't affect my model? When I opened another model, I didn't get this warning.
Anyone has got this issue? Any help would be appreciated. Thanks.
Replies (9)
Message 2 of 10
jay_colcombe
Was the Autodesk Viewer link shared with anyone else? I can only think it has been opened on a PC with an addin?
Can you review what addins you do have - Manage Tab > Extensions Panel > Add-Ins Manager
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 10
BJX916_XUANWU115
yes, the model was shared to someone via a link. I did install add-ins on Revit 2025, but I didn't use any of them when I created the model.
I didn't see the extension panel, but I have add-ins tab:
Message 4 of 10
Choose option 2.
Message 5 of 10
BJX916_XUANWU115
do you mean to choose "Do not warn about this updater..." or option 2 from the link: Install the 3rd-party add-on?
Message 6 of 10
jay_colcombe
The Add-ins are also the additional Tabs such as DiRoots Mlabs plus the Coins addin so these would be party to the issue!
Jay Colcombe
Message 7 of 10
jay_colcombe
The Add-ins are also the additional Tabs such as DiRoots Mlabs plus the Coins addin so these would potentially call the message!
Jay Colcombe
Message 8 of 10
Yes it is quite obvious unless you are reading from bottom up.
Message 9 of 10
BJX916_XUANWU115
I see, thank you for your help.
Message 10 of 10
BJX916_XUANWU115
ok, I will choose "Do not warn about this updater...", thank you!
