Missing properties in IFC for steel connection elements
giovine.alessio
Observer Observer
giovine.alessio
Observer
Observer
I need to model some steel elements as beams, columns and various steel fabrication elements in Revit 2022. At these elements are assign shared parameters and I need to export these parameters in custom property sets but for all the fabrication elements this property set is missing and also the properties are not exported.
Thanks for your support.
Alessio
pavlo
I just want to add that I use steel plates in Revit. The steel plates IFC model do not have Length parameter and do not have Width parameter. I hope it would be solved in Revit with the next release. I use BIMcollub to view IFC model. In Sollibry I can see steel plates parameters (Length/Width) but do not see bolts parameters. Something goes wrong with steel tab.
