Missing Parameter Column in "Type Properties" when using "Edit Type" of Family.
paul.eterovichY6MNN
Message 1 of 11
paul.eterovichY6MNN
Does anyone have any experience with this. I have never seen it before:
The parameter column is missing, but it is showing the value of the parameter column.
This is what I am used to seeing:
Anyone know what is going on here and how to fix it? Revit 2024.
Replies (10)
Message 2 of 11
jay_colcombe
I can only assume its a visual issue and maybe related to display settings and monitors etc.  I would first check any settings on your PC for display which may be causing the issue, unplug external monitors or devices, then I would suggest resetting the Revit.ini
How to reset the Autodesk Revit ribbon, toolbar, and browser to default settings
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 11
maclean_a
I have this problem too (but with Revit 2025). Reset suggested by jay_colombe does not help. Very difficult to work like this.
Message 4 of 11
jay_colcombe
Is it possible to make the middle columns thinner/smaller by dragging the split line as it may be pushing it out of the dialogue box as they are too wide?
If you hover on the Left Hand side you Header Field you should see the Stretch arrows to readjust the column width
Jay Colcombe
Message 5 of 11
maclean_a
thanks for the suggestion, but no this is not the answer. when the type properties window is first opened the column is there and appears as normal. the instant an entry in the "value" column is selected the "parameter" column disappears. closing and reopening the type properties brings back the parameter column, but once an entry in the value column is selected it disappears again. i wonder that this has happened because i'm using multiple monitors at different resolutions (laptop driving matching dual external monitors) though now that it's begun the problem persists when using laptop only.
Message 6 of 11
dale_delson
Community Visitor
Community Visitor
This solved it for me! Thank you!
Message 7 of 11
Syed.hussainDTW9W
Community Visitor
Community Visitor
Select any Wall>edit properties>Edit Structure>then drag the Function Column to make it wider>Cancel.
I did it my problem Solved
Message 8 of 11
joaquim.moral
Hi @paul.eterovichY6MNN,
Did the information provided by @Syed.hussainDTW9W  answer your question?
If so, please use Accept Solution so that others may find this in the future.
If not, let us know so we can keep helping you.
Thank you very much!
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager
Message 9 of 11
maclean_a
no, this is not at all the problem. the column is missing not minimized.
Message 10 of 11
celeste_delacruz
Community Visitor
Community Visitor
Excatly, the column is missing, not minimized, I tried a lot of things but nothing works, including the firt solution abou Revit init, I reinstall Revit but the part of parameters didnt appears, help please
Message 11 of 11
tmasriBWSSQ
Community Visitor
Community Visitor
It did solve the issue for me. Thanks!
