Merge wall footings with adjacent footings without lines at joints?
I have two related issues that I need advice on. Merging of footings.
1. When placing a wall footing along a wall with openings, I always get a break in the footings at the openings when first placed. See wall before footing below:
Wall with footing below, footing breaks at openings when footing first placed:
Wall with footing dragged "closed" at openings. "joint" line remains.
THIS IS MY MAIN QUESTION: How do I remove these "joint" lines?
2. Similar question, but the joint is happening with an adjacent footing, wall & spread, and the joint line is not going away, although at the other adjacent joint the lines went away. One is a wall footing, and one is a spread footing, again, same situation adjacent and it worked. All footings on same elevation and same depth. See clip below:
Any advice is greatly apprecitated.
