Merge Files
Merge Files
Merge Files
Morning!
I would like to know if it's possible of course, how can I merge 2 files of Revit? and since I know it's possible to two Computer's working at the same time in the same revit file can you explain how?
Thank you very much.
Best Regards
To be more precise I'm asking for your help with "Central Revit files"...
Thank you
Best Regards
RLory
I got it. I was able to copy and paste elements from one revit file to another. The only way I found that it worked was by
1. selecting desired objects in file 1
2. press CTRL+C to copy to clipboard
3. in the menu bar, go to VIEW and switch windows to view file 2
4. press CTRL+P to paste to file 2 where they need to go
5. Sing Hallelujah! Yes!
I was so excited when this actually worked. I had made a deck with furniture, office furniture, and more.  I really, really didn't want to redraw them. It seemed to me that clicking COPY from the menu bar and PASTE in the file 2 did not copy the elements I chose to the file. So, try the above directions and, hopefully, you'll have the same success as I did.
Amy
That did work! Thank God. I was having so much trouble. Thank you.
-John
