memory low
memory low
memory low
we are finding  problem in ram meory,  whlie we are working the revit shows low memery message and the system becomes very slow.  file size is only 13 mb, ram is 16gb
arief.rahman
Hi Shiraz,
From Windows Task Manager you can select Processes click sorting of Memory, you can see which application consume the most memory (RAM).
You can increase you virtual memory from Control Panel select System -Advanced system setting- Advance tab - select setting button under performance. You can increase virtual memory until 3x of your physical memory (RAM).
Check this link below regarding how to increase virtual memory :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8018971&linkID=9243099
regards,
Arief
Arief Rahman
