Make a list in the shared parameter
husam_al-jawhar
husam_al-jawhar
Hi all,
I have an inquiry about a concrete structure that I want to inspect. I want to add a parameter named 'deficit' and create a list of inside parameters under the name 'deficit.' When I press on this list, it should display three problems: heavy shear, heavy deflection, and no deficit. If I choose, for example, 'heavy shear,' another parameter should advise on the type of test, such as UPV. How can I achieve this? Thanks.
jay_colc
you would need to create Yes/No Parameter's with IF Statements and Formulas for each scenario.
There are a lot of resources out there and YouTube will have visual walkthroughs
Set yes/no family parameters in Revit (autodesk.com)
Revit Formulas for Everyday Usage - EVOLVE Electrical Help (evolvemep.com)
Jay Colcombe
Autodesk Certified Instructor
