Lock location of a group
I'm trying to change 'group 1' into 'group 2'. I need the elements from group 2, but the location and position of group 1. The problem is, I need to lock the location of group 1 (see attechments).
filipefrancisco
Select the group and then PIN the group
Hope that help you
Cheers
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
That was the first thing I tried... Unfortunately the group still changes it's position
Max.Kotsar
Hi, arnoud!
If You want to take elements from Group 2 and place it to Group 1 position, you must rotate Groups origin like in attached video.
Max Kotsar
Сообщение полезно - Проблема решена -
