LoadingAutodeskFamily - External component has thrown an exception
AnthonyGardner
AnthonyGardner
Is any else having this issue in Revit 2022 when trying to open a new local file from the recent files start up screen?
We are selecting the project. Append Time Stamp. Then before the model opens we get this error (not a cloud model)
Hit Close and the model doesn't open. If we do this 3-4 times it will then open without the exception.
We have this on multi models and multi computers in the office. I have recreated the central files, audited, compressed the central on sync. All users running lastest version 22.1.21.13.
Something weird is that if the user creates a new local file from the Open Dialog Box we don't have the error.
Error is the error message from the journal file.
' [Jrn.ExternalEventExecution] Rvt.Attr.AddInId: 87a72273-3ab1-404e-b6fd-ee0f60ba0e1b Rvt.Attr.AddInName: Application LoadAutodeskFamily Rvt.Attr.AddInVersion: 22.1.21.13 Rvt.Attr.ExternalEventName: CEFRevitUtils.ExternalEventHandler Rvt.Attr.VendorDescription: Autodesk, www.autodesk.com Rvt.Attr.VendorId: ADSK
Disable the Add in.
AnthonyGardner
Ok but I thought it was core part of Revit ("Load Autodesk Family")
What implications do you think there may be by disabling it?
AnthonyGardner
Found the problem, another add-in was interfering with the inbuilt Revit 'Load Autodesk Family' Add-in.
TB3
Glad you found the culprit!
I am experiencing the same error - could you maybe tell me, which plugin was the offending party in your case? If I am in luck, I have the same one intalled and it could save me some hunting.. 😉
Thanks in advance!
Tommy
