Linking Plant 3d object
chriskD6WP2
chriskD6WP2
I've got some models a client gave to me which were created in Plant 3D. Whenever I link them into my Revit model, all I see are wireframes. Is there some plugin I need to view the objects correctly?
ArmanMargaryan
Have you tried Exporting AutoCAD then Revit?
See the attached video.
https://www.youtube.com/watch?v=awl_9i_fQgQ
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
ennujozlagam
try to import  cads file into a revit family like Metric Generic Model.rft (in 3d mode view) , you can change the detail level and visual styles in the family itself then save to a filename and load into your revit file and see if helps. thanks
chriskD6WP2
I found the solution. The Plant 3D user has to use the command EXPORTTOAUTOCAD for the model to show up correctly in Revit.
