Linked IFC from Tekla, hidden lines
SEFLIL
SEFLIL
Hi!
I have linked an IFC exported from Tekla into my revit 2024 for detailing. Is it possible to display the model with hidden lines? I´m having issues with this. For example (see attached images): A beam is connected to a column web, when I switch from wireframe to hidden lines it lookes good at the right section view but at the left both the web, inner lines of the flanges and the bolts dissapear. Does anyone know and have a sollution?
jay_colc
It looks like the one is a section from inside the Column Flanges and the other is a Section looking from the Outside of the Column.
Does editing the View Depth and Depth Clipping have any influence In the properties Palette
Also check Show Hidden Lines in the Properties Palette
Jay Colcombe
Autodesk Certified Instructor
