Linked file icon
Linked file icon
PrathapSekar
Message 1 of 12
Linked file icon
PrathapSekar
Dear Community members!!!
 The symbols (Highlighted) representing what? We have linked models in our main model. but we don't have any nested links on that, but the icon shows strangely.
Many Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Replies (11)
Message 2 of 12
m-de-lange
We just had a project with the same broken icons...
no one has any idea?
great...
Message 3 of 12
ennujozlagam
check other user's if they already synchronize. or create a new central and see if helps. thanks
Message 4 of 12
m-de-lange
we're simply trying to understand what these icons mean and why they are different to the others..
as long as we don't understand that, trying to fix it would be nearly pointless.
Message 5 of 12
ennujozlagam
are you using C4R?
Message 6 of 12
m-de-lange
Speaking for myself, we are yes
Message 7 of 12
ennujozlagam
there are previous thread for this issue, you can refer to these LINK and LINK. thanks
Message 8 of 12
m-de-lange
Neither of the links you provided helps with our question.
The linked models aren't too big and we don't have a broken icon on BIM360...
We have different linked model icons inside revit in the open project.
What do these icons mean?
There i no problem... it all works fine, the only strange things are these icons.
Message 9 of 12
ennujozlagam
i can't help much?
Message 10 of 12
m-de-lange
Well after some searching and searching on the internet without any solution i finally found it in Revit.
Not sure if we're stupid or simply never paid attention to it but the difference is in the linked model reference type.
Which can be either Overlay or Attachment.
When the icon is not a blue arrow but 2 small white squares with smaller blue arrow, it means that linked model is set to Attachment rather than Overlay.
Message 11 of 12
m-de-lange
If this answer has helped anyone please mark it as solved!
Thankyou!
Message 12 of 12
Mohammad_Adil
This means that this link is an "Attachment" and not "Overlay" see this link
To understand the difference between "Attachment" and "Overlay" follow this link
