I'm working on a project with a campus of 10 buildings. Each building has 4 floors. The walls were created in the architectural model. I'd like to create a wall schedule in my structural model that will tell me linear feet of all existing walls and all demoed walls by building and by floor. Does anyone know what parameters to add and how to filter a schedule to generate this information? I'm thinking a may just have to calculate it the old fashion way with pen and paper but I'd love it if Revit could do it for me. So if anything changes I won't have to recalculate.
Solved by samuelsanf. Go to Solution.
When you are on adding fields to schedules windows be sure to check "Include Elements from links" when creating the schedule for Wall Category.
Then you add the fields:
On filter tab, you can Phase Equal to New Construction to only view new walls.
You can use the tab Sorting and Grouping to improve your schedule:
For example, create group by Level with a Header title, then sort the walls by type first, and then sort by height. Uncheck Itemize every instance to allow calculations and grouping per type of wall. And mark "Show count and totals"
In formatting make invisible the fields: Level and Phase. And for Length and Volume fields select "calculate totals".
What exactly you want to achieve?
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
Do you mean you want to calculate the whole length of walls in buildings?
