levels order on the project browser menu
Hello there,
I would like to know if there is any way to re-order the levels that show up on the project browser menu, since they are out of place, like you can see in the  picture below. The idea is to have the Floor -3, -2 and -1, before the Floor 0 and the other that are above of them.
Thanks you and best regards.
L.Maas
When you go to the View tab and look at the Window Panel There is a function User Interface At the bottom of the list you will find Browser organisation. Here you can make settings how to organize your views. Now they are probably sorted alfabeticaly. You could sort on Associated Level for instance.
Louis
Please mention Revit version, especially when uploading Revit files.
EdwinG
