Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Label a Model group
8 REPLIES 8
Message 1 of 9
11505 Views, 8 Replies
Label a Model group
Hi
is possible make labels for model groups
I have some groups and i need to tag the groups to do a sheet
I have this ....
Groups.pngAnd i need some similar to this
Required Label.pngSome help Please
8 REPLIES 8
Message 2 of 9
catalin_lang
This is not possible.
See https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Please also visit the Revit Ideas page and vote for this idea to let us know it's important to you.
catalin.lang
Message 3 of 9
in reply to: catalin_lang
ok
thank you any way
Message 4 of 9
For what you do I think Assemblies is more appropriate than Groups.  You can tag Assemblies as well as having the entire Assembly views available for you.
Message 5 of 9
RPTHOMAS108
Pile caps are pretty standard, typical details could be done as detail items on a drafting view.
Usually would have a set of details with alphabetical dimensions and then reference those lettered dimensions in a schedule generated from the pile cap types within the model (with same lettered parameter names).
e.g.
Message 6 of 9
in reply to: ToanDN
I took the suggestion and I'm using assemblies
it's possible assembly tag say me how many are in use?
For exemple
type mame: PC
in use on the model: 3
Message 7 of 9
404 dead link
Message 8 of 9
leonHKFTG
There is no direct way, as of today.
Add a filled region to the model group as an attachment. Make sure that filled region isn't opaque if you need to see the model group, make sure its boundary lines are invisible. Then add a type mark to the filled region you just attached to the model group. Then tag again, this time Revit will detect the filled region and will tag it, you'll be tagging the model group indirectly.
Message 9 of 9
kryadchenko
@catalin_lang
Your link doesn't work anymore.
