Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Join families
4 REPLIES 4
apdim
289 Views, 4 Replies
Join families
Hey,
Im trying to join two families in one. Materials and category are the same but I still cant join them. Any ideas?
4 REPLIES 4
jvpantin2
in reply to: apdim
  1. What do you mean with "join"? Connect both elements in model? Nested family? Merge them in one single family?
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
apdim
in reply to: apdim
Merge them in one family. I cant mark any of tthe elements. If I want to create nested family-for example if i want to add rigel to column. in column file I cant select rigel to join. I have checked shared parameter.
jvpantin2
in reply to: apdim
Now I'm away from my PC so I can't take a closer look to the families. But everything points out that you will have to model the singlest element inside more complex element's family file (i.g. column in rigel file). Creating a sweep blend will solve the angled connection, use reference planes to draw profiles and control angle.
apdim
in reply to: apdim
I created it as single family and its working for now. Any ideas how to snap precisely girders to bearings? I cant level them by height. 3D snap is not working.
State of Sustainability Webinar
