issue with advance steel linked cad
andres_urrutia
Message 1 of 9
andres_urrutia
hi everybody
I have linked an advance Steel model but in realistic view this is showed as a wireframe and even with its red lines..
is there any solution to this issue?
Replies (8)
Message 2 of 9
MostafaElashmawy
From Manage>> object styles>> linked models>> open the + beside your file then for the layer having your elements, adjust the material and the projection lines.
Mostafa Elashmawy
Message 3 of 9
andres_urrutia
I tought that but there are no changes on the model.
could it be this message when it is imported or reloaded?
Message 4 of 9
MostafaElashmawy
Regarding this message, go to advance steel file. write the command "Proxygraphics" then 1. save and reload.
Mostafa Elashmawy
Message 5 of 9
andres_urrutia
thank you for your help but the message is the same...
Message 6 of 9
andres_urrutia
Does someone know another solution?
Message 7 of 9
robertwmerriman1
Hi is the Advance Steel model that is linked the intelligent Advance Steel file?
Have you tried exporting the Advance Steel ans importing into Revit via the Advance Steel extension? You could even import into a new RVT then link the RVT files
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
Message 8 of 9
andres_urrutia
No, I have just imported as a dwg...
Message 9 of 9
robertwmerriman1
Ok so I think the issue is Revit strughles to see the Advance Steel elements and manipulate the graphics
If you want to link the DWG then you should take a copy of the Advance Steel DWG then follow the steps in the link below, this MUST be done in a copy of the model, the DWG will then just be 3D solids
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
I would strongly look at the intelligent workflows between Advance Steel and Revit using the Advance Steel extension in Revit, you can import your Advance Steel model and it will convert the Advance Steel objects into Revit Objects
We have done a lot of work ane webinars on these workflows and they can be found below, if you can upload your Advance Steel model I could record a video showing the basic steps
https://www.graitec.co.uk/cad-courses/training-tutorials-and-webinars/advance-steel-content-portal
