Issue - Cannot keep analytical surface connected
vilian_k
vilian_k
Pls Help.
In Revit 2024, when I try to change the height of the level​ is appearing​ - "Cannot keep analytical surface connected". In Revit 2024 in properties of structural elemenets there is NO cheking - Enable Analytical Model. What can  I do?
mihai.sandu
Hello @vilian_k ,
Could you attach the Revit model and describe the steps that you are doing before the error message appears?
Mihai Sandu
Sr. QA Analyst
vilian_k
I want to change the height of the levels.
mihai.sandu
Hi @vilian_k ,
Thank you for reporting this behavior. I reproduced this issue on my side, documented it and sent it to the development team for further investigation.
For now I could not find a good workaround, sorry for that.
Hopefully we will be able to deliver a solution as soon as possible.
Thank you for your patience in this.
Mihai Sandu
Sr. QA Analyst
lukedobben
Observer
Observer
I am having the same issue. The "Accepted Solution" above is not a solution.
mihai.sandu
Hi @lukedobben ,
This issue was reported on Revit 2024 and it was fixed and included in Revit 2024.1 and Revit 2025.
If you are using Revit 2024, please update to Revit 2024.1.
Mihai Sandu
Sr. QA Analyst
dgodave
I'm having this problem in R 2025.3
