Is there anyway to rotate Revit Schedule 90 degree inside sheet?
L.Maas
Yes, use the function on the options bar
Louis
Please mention Revit version, especially when uploading Revit files.
Oooh, I didn't notice that Thank so much for your help
steve.lacroix
You can set the headings to Vertical, but how do you rotate the Body text?
Also how can you set the Appearance Graphics Build schedule to Bottom-up?  It's greyed out.
@steve.lacroix wrote:
You can set the headings to Vertical, but how do you rotate the Body text? No can't do.
Also how can you set the Appearance Graphics Build schedule to Bottom-up?  It's greyed out.  Only for Revision schedules.
