Is there a way to join a diagonally placed beam that links a girder to a column?
I'm trying to see if it's possible to sort of miter a column and two beams together. I just want to know if it's possible to make the column and beam families comply to what I want without faking anything.  Note: The two beams are the same size but the column is a smaller size.
Tom_Kunsman
sadly no, you will need to use some detail lines and or voids to really get a "clean" cut version like you are showing. revit does not like to join between different categories such as columns and beams. they are two totally different things in the software
EdwinG
Yes you can
see pic's below.
Use by face select beamselect beamsketchsketchdo the same for the columndo the same for the column
Rob_Merriman
Hi @Anonymous
If you are using Revit 2019 or later then yes this can be done with the tools added to the Steel tab.
If the column & beam are simply mitered then use the mitre command, if you want a division plate between them then use the cranked beam to beam connection.
I have made a short screencast video demonstrating both methods - https://autode.sk/3dE3Xoz
One thing to note when using these Steel tools is the shapre of the beam changes to a Steel Fabrication Format, this disables things like autojoin, cutbacks, groups, assemblies. Once anything from the Steel tab is placed the only way to get back to a "normal" Revit beam / column is to delete and remodel. Refer to this page - https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-StructEng/files/GUID-8381A08F-CBCD-4215-AB36-82648C07B8F6-htm.html
Rob Merriman, AEC Technical Lead, Graitec
@Rob_Merriman
Thanks for your detailed solution and reminding me that the "Steel" Tab is a thing, haha...
