is it possible to align text to modeled bracing in bracing elevations? Revit 2023
mkennedy
mkennedy
Right now I'm checking the angle of rotation for the bracing and then rotating text for the Afs and Tfs, be alot faster if there was an align text command, is there?
perez-tony
No, the align tool does not work on text notes.  The link below demonstrates how to rotate text to align with surrounding geometry.  Another solution would be to use a framing tag.
https://forums.autodesk.com/t5/revit-mep-forum/align-text-with-reference/td-p/11105849#11107116
