Cannot progress custom steel connections
lwindsor73
lwindsor73
Hi All,
I'm relatively new to Revit and have a set of tutorial videos to follow. I am stuck on steel connections as I have a bracing connection example showin in attached image. The dialog box shown attached also does not pop up on my machine when adding connection entities.
Is there some setting that I have not got turned on or is this an issue with my instance of Revit?
jay_colcombe
This was also recorded with Edit Group and Assembly so may be a similar issue.
In "Edit Group" or "Edit Assembly" mode, Finish and Cancel buttons are missing from Revit ribbon
Sometimes if docked it can be off the end of the Ribbon
Jay Colcombe
Autodesk Certified Instructor
piotr_pysz
Hi, @lwindsor73, I think this is a different thing - a limitation that we currently have with custom connections. You can only create a custom connection with a maximum of three input elements. The connection that you show has four, so it can't be turned into a custom one currently.
Piotr Pysz
Product Manager
