Instance parameters in family will not change in revit 2018.1
haydenwse
Message 1 of 42
haydenwse
I have families with instance parameters that change stuff in the project which have all other versions but in 2018.1 they will often not work. I created a video that shows what happens. https://www.screencast.com/t/XCsrlGwERKO9
I can check the box or change the numerical value and the "apply" button will become active until I try to select it. then it grays out and the change that I made reverts to what it had been.
Sometimes if I go to a different view or reopen the project or sync then it will work as it should.
Replies (41)
Message 41 of 42
fg
I Have found that sometimes you have to race the apply button and quickly click it before it grays out!  No always an easy task and not always effective.  This seems like some kind of weird Revit-to-Windows related bug.
Message 42 of 42
lmorales
This was it for me...
@chadclary wrote:
I've been noticing this as well, although it seems to have started the other day.  On a whim, I uninstalled the Structural Precast addin (it kept throwing errors anyways) and it seems to have resolved the issue, at least in the 30 seconds of testing I've done since then.  I'm guessing it has something to do with refreshing the install itself similar to Jake reinstalling but can't be certain.  If you are having an issue a repair install might clean it up.
...going to the Precast Tab and turning OFF the On/Off button (rather than completely uninstalling), and now I can set instance parameters form within the Project.
